98 coolant leak -- SOHC -- Under engine | Ford Explorer Forums
Stick_man
NYC, NY
1998 Explorer V6 SOHC
the leak looks like its coming from a part which I can't identify from under the engine and leaking down on the axle
is this the thermostat unit i been reading about that is infamous on the 98?? if so what do have to do to remove to get to it?
can you use barrs stop leak more than once btw? I tried Barrs and it did nothing.
how many shop hours would it take to repair this?
Happy thanksgiving all :D:D:D
The lower housings have been known to seep for years without issue, or let go without warning. Like most engines with aluminum heads, the 4.0L SOHC does not react kindly to overheating. Your call, pulling heads to replace gaskets or replacement heads can't be fun or cheap. Basic repair for the newer style housing only requires the RH144 lower housing, both sensors with clips, and upper and lower o-ring seals. Another option is an aftermarket replacement complete with the older style threaded sensors. I've heard mixed reviews on them.
I don't think it is leaking from the housing
The coolant runs down the passengers side of the engine
That is too far and too concentrated to be complete my from the thermostat
Mine split and it took me a while to realize it was in fact the thermostat housing. Coolant leaked down right side of engine.
Where was it cracked?
I took off the whole intake had 2 of the thermostat screws and the hose off and I'm like ... there's no coolant around here and it doesn't look visibly cracked anywhere. This is a waste of time.
Yes that's a waste of time, you should put a pressure test rig on after pulling the intake. I should have done the same AFTER installing the first defective replacement, you want to talk about a waste of time! It takes me almost six hours to R&R a housing, and I use air and torque wrenches for everything. Problem I had was putting it ALL the way back together and get it running since I had no test rig. Three times in one weekend before getting a good housing.
got a wire harness running down the middle of mine ... it splits and goes 2 directions above the rear bolt making removal difficult.
anyone know what the wires are? how much work is removing intake manifold?
On mine that harness is for the CKP sensor. I removed it.
went out and bought an 8 mm ratchet wrench. i got the housing off but the thing was so brittle 2 of the bottom tabs came off and the lower hose nipple broke and fell down the hose to the water pump.
how do i get this stuff out?
how can I get the tabs out of the engine block hole. I tried putting grease on my hand and reaching down there with my fingers but nothing stuck to it
ohh god, you sound like me when I did my steering rack install. I destroyed the aluminum thread on the pressure hose and had to buy a whole new rack. you can try some sort of magnet, something you could stick down it, not just drop down by string.
There's a thought.
I also suspect a piece of the lower nipple went down the lower hose into the radiator perhaps.
Maybe a flush and fill at a shop will take care of both?
Flush? Wouldn't hurt to try. Stick a water hose in the radiator and increase pressure slowly. Broken plastic pieces "should" float. GL
This wire harness is driving me bat-sh*t crazy trying to get the new housing back in.
It is impossible too put it in with the rear bolt intact and that harness in the way.
