- June 16, 2003
- Humboldt, KS
- 2000 Mounty
Is the truck parked pointed downhill? If so, and the gas tank is under 1/4 full it might not be pumping fuel.
You can get a cheap -round dial type air pressure gauge from walmart under 5.00
There is a shrader valve on the fuel rail. push the tire gauge down hard onto it while someone tries to start the engine. Beware, a tiny bit of fuel will spill out when you apply the gauge, and when it is removed, so hold the downward pressure on it while testing and remove the fitting as quickly as possible when finished. It should be just like checking tire pressure once you find the valve and remove the cap.
post back the fuel pressure reading you get please.
