98 explorer cabin air filter
J8McMahon
1998 Ford Explorer XLT V8
Is there a cabin air filter on the 1998 explorer xlt v8, if so please tell me where I can find it. Thank you! :cool:
K Is there a cabin filter in my 2001 explorer sport? Stock 1995 - 2001 Explorers 0
F 95 Ford Explorer code 998, 113, along with ABS light Stock 1995 - 2001 Explorers 2
L 97 Explorer alarm/remote problem Stock 1995 - 2001 Explorers 0
T 09/2001 Explorer Sport- 2 Door Manual Stock 1995 - 2001 Explorers 8
K Where can I buy the right door lock control rod 99 Explorer/Mountaineer Stock 1995 - 2001 Explorers 7
N 1999 Explorer Grinds When Turning Left & Shakes Stock 1995 - 2001 Explorers 6
K Convert My 1998 4.0 AWD manual transmission Ford Explorer to 2 wheel rear drive Stock 1995 - 2001 Explorers 1
J 1997 Ford Explorer XLT--Need Part F77Z3B676EA Stock 1995 - 2001 Explorers 15
J 1996 Explorer Limited stereo system Stock 1995 - 2001 Explorers 1
O Odd issue with my 99 explorer Stock 1995 - 2001 Explorers 75
I Lowering explorer Stock 1995 - 2001 Explorers 8
T 1999 Explorer xlt manual transmission problems. Stock 1995 - 2001 Explorers 5
A Abs Pump Test - 1997 Ford Explorer 4.0 OHV Stock 1995 - 2001 Explorers 1
A 99 Explorer fuse 26 Stock 1995 - 2001 Explorers 21
J ABS LIGHT ON!?!? ( 97 Explorer XLT 4.0 Stock 1995 - 2001 Explorers 8
T Updates on my explorer Stock 1995 - 2001 Explorers 4
E (1997 Ford Explorer bolt hole spacing on flange) Stock 1995 - 2001 Explorers 0
L Keyless entry 2000 Ford explorer XLS Stock 1995 - 2001 Explorers 2
D Possible PCM damage, PCM and electrical function diag. 2000 Ford Explorer Limited Stock 1995 - 2001 Explorers 1
Brem95 Has anyone camped in a 97 explorer sport? Stock 1995 - 2001 Explorers 1
M Radio with no sound 95 explorer please help Stock 1995 - 2001 Explorers 2
O 1998 Explorer XLT: ABS ISSUE / DROVE W/ PARKING BRAKE Stock 1995 - 2001 Explorers 26
S 98 explorer HELP!!! NEW alternator put in, mechanic says stuck in "anti theft" stealth mode **UPDATE**WAS THE STARTER -NOW BALL BEARINGS BRAKES/ROTORS Stock 1995 - 2001 Explorers 47
T Explorer Audio Problems Stock 1995 - 2001 Explorers 6
T Explorer Specs. Stock 1995 - 2001 Explorers 2
S 1996 Explorer V8, 2WD intermediate steering shaft. Stock 1995 - 2001 Explorers 1
E 99 Explorer XLT 4.0 V6 SOCH running rough Stock 1995 - 2001 Explorers 3
G '98 Explorer Sport potential problem areas? Stock 1995 - 2001 Explorers 1
B 1999 explorer rear window Stock 1995 - 2001 Explorers 1
L 1997 explorer jerks right before it turns on Stock 1995 - 2001 Explorers 2
C G-WAGON style DRL on FORD EXPLORER Stock 1995 - 2001 Explorers 0
S What rear end do i have in my Explorer? Stock 1995 - 2001 Explorers 2
H Explorer Sport front end noise Stock 1995 - 2001 Explorers 3
S 1996 Explorer 5.0 Drivers Side Exhaust Manifold Removal Stock 1995 - 2001 Explorers 9
C I have a 1999 ford explorer that has a loud banging when drive , I was told it was the transfer case . How can I tell ? Stock 1995 - 2001 Explorers 5
A Everything is stock. 96 Ford Explorer radio has no audio. Display works, stations work, ect. Just no volume. Stock 1995 - 2001 Explorers 8
I Buying a 99 explorer 4x4 first ford what should I look for any common problems? Stock 1995 - 2001 Explorers 24
C FORD EXPLORER REVIEW - probably the most detailed analysis of popular SUV Stock 1995 - 2001 Explorers 20
T 2000 Ford explorer transmission problems Stock 1995 - 2001 Explorers 2
Z 1996 explorer 4.0 engine compatibility Stock 1995 - 2001 Explorers 4
L 00 explorer 4 wheel drive dash lot was flashing? Stock 1995 - 2001 Explorers 2
E 2001 ford explorer sport Stock 1995 - 2001 Explorers 2
M 03 Explorer Sport XLT - Alernator still not charging after replacing 3 times in 5 days Stock 1995 - 2001 Explorers 18
L Happy 250,000K Explorer Stock 1995 - 2001 Explorers 15
S ‘99 Explorer, power steering hose and Coronavirus Stock 1995 - 2001 Explorers 5
L 98 Ford explorer. Cranks but no start Stock 1995 - 2001 Explorers 2
F What items need to be done before long trip - 1998 Ford Explorer XLT w/ 215,000 miles Stock 1995 - 2001 Explorers 5
K 99 explorer wipers and interior lights wont work Stock 1995 - 2001 Explorers 3
M Replacing cat. converter on 1995 Ford Explorer 146,000 miles , second owner Stock 1995 - 2001 Explorers 0
T popping under explorer Stock 1995 - 2001 Explorers 7
Similar threads
