astrochimp
- September 10, 2001
- grand rapids, mi
- 98 xlt
I'd order one of these first:
http://www.amazon.com/Dorman-77156-..._1?ie=UTF8&s=automotive&qid=1293655249&sr=8-1
Then begin the tear down. Or at least get one from a U-PICK scrap yard or something.
That way you don't have to work twice. Unless you don't mind driving around without a door panel until you get the part.
pull the steel bar that is sticking out of the door to the left.
If you have most all of the pushpins out, you can try pushing the panel up and tilting forward. One or two shouldn't be too difficult to shear or pull free from their mounting bracket (just look at the others you have already pulled - cheap piece of plastic pushed in to a slot in the door panel). The whole panel needs to lift about 3 or 4 inches to take off of the door. It should be able to clear the dash.
Anyways the bar needs to be pushed towards the rear of the truck. By your pic, to the right.
That happened to my XLT. 'Cept it was the drivers door. Drove around like that for a month or so. That was years ago.... Anyways the bar needs to be pushed towards the rear of the truck. By your pic, to the right. You will feel the latch open up at the end of the rod. Imagine pushing something to mechanically open with a wire coat hanger. Give it a few quick shoves(?), or pushes. It always took me from 1 - 5 times to open the door.
