Look in every mag test and you'll see the 5.0 Explorer in the 8.3 second range with the sohc being .1 or .2 slower. So theres something wrong if you guys are as slow as an ohv V6 Explorer. My 94' ohv gets to 60 in about 9.9 seconds now, stock it was around 10.5, so that should tell ya somethingOriginally posted by Knoxfan
That's awesome! That helps me too. Because I'm only getting in the mid 9's. i don't understand how guys are getting 8's? Maybe the G-tec add's another three inches too your manhood too.
actually, unless you have a major power adder or built motor, the 2wd will be quicker off the line. lets face it, its not like the 2wd with a catback and intake is gonna sit there and spin.lol the added weight of the AWD will make it slower off the line, as the 2wd will be able to "hook" without spining much.Originally posted by DarkFox1
well you are AWD.. that gives you much better traction there.. and probablly better accel.. I can't help but think however the AWD model is heavier and would thus be a bit slower given the same conditions and ruling out traction.
Originally posted by james t
no, the cam i have makes the E-303 look like a toothpick. lol i have a Comp Cams blower cam that is, um.... well its just friggin big. ill put it this way, im gonna have to fly-cut the pistons to run it.
ha, no prob, just make sure to get the newer digital one, I'm not sure if they still sell the older unit but it didn't have as many features on it.Originally posted by Knoxfan
Hey all. I'm just catching up here. So I may be a little slow. Saleen, I was just giving you **** about the g-tec. I'm sure it works awesome. I'm actually gonna buy myself one for x-mas.
DarkFox: I think I have a u-joint going out because I'm starting to hear some stuff, and I don't think it's the tranny. After I take off, I get up to about 35 or so and let it shift into the right gear(3rd?) Then I let of the gas for a second. I tap on the gas and it's almost like a slip before it kicks in. BUT!!!, after i cleaned out the dust cap from my throttle cable(throttle slack check and it had paper in it too), I put 92 octain gas in my X. It's almost like a completely different vehicle. I can get into the mid 9's doing a 0-60 now.
