ngbeau89
- October 25, 2016
- LA
- 1999 Explorer XLS
Good day everyone. Hoping to get some answers...
I'm having some trouble with my Explorer. I'll start back with the major issue and work to where I'm currently at. I was driving to college from home and on my last bout before I got to school, the engine overheated and I noticed the truck had a clanking sound instead of the usual "roar" (don't laugh, but this is my biggest engine I've ever owned. Had a civic due to traveling a lot in the Army) while i was accelerating. I pulled over, replaced the coolant that was missing, and drove the rest of the way to school and it didn't overheat. I got the vehicle home via tow truck JIC. I did a couple google searches and found some possible fixes.
I first replaced the thermostat, which was in pieces upon taking the housing off, then I noticed any fluids I put in the radiator were draining pretty quickly, so I replaced the radiator, and upon inspection, I noticed the old radiator was blown. Now, there's no more overheating, no more fluid leaks, etc. Just a really bad, rough idle. I changed the IAC valve as well just in case. My check engine light was on, so I drove to the local advance store and had some codes read. I had a misfire in cylinder 3. I changed ALL the spark plugs, the coil pack, and wires.
After firing up the vehicle, my buddy and I noticed a decent amount of white smoke coming out the exhaust with some water. So thinking it might be a head gasket, we checked the oil for your the classic over-creamed-coffee or white color, but it was fine. My Explorer has been using an excessive amount of coolant lately...
Anyways, the idle is noticeably still bad, but not as bad as it was before. I'm suspecting maybe a blown head gasket, but the oil wasn't milky or creamy. I read something about maybe a PCV replacement, but I'm not a mechanic.. It blows white smoke when its cold, warming up, and when running at operating temps. IAC Valve was changed as well. Any other ideas? I'm at a loss.
