RickMar
- April 11, 2009
- N. Andover Massachusetts
- 99 Mercury Mountaineer
Thank you for taking the time to read this post.
I replaced the spark plugs in my 99 Mountaineer 5.0L with 205,000+ miles.
Believe it or not the Mounty was running just a little bit ruff at idle. I had plenty of power and smooth acceleration. Now and then, just to clear it out (I could wind it up to 110 MPH) on the highway, with well over 100,00 miles on the spark plugs. I was amazed of how well it ran with so many miles on the same plugs.
With firing order 13726548 I pulled the plug from cylinder 1. It looked clean burning "Normal" light brown in color on the insulator and had a gap of over .104+. I expected this because of the high mileage on the plugs.
Cylinder 2 (same condition). Cylinder 3 and 4 slight (Ash Fouled) with .104+ gap.
Cylinders 5-6-7-8 same normal condition as cylinders 1 and 2.
All plugs had a huge gap, all equal at .104-.118. All Motorcraft Platinum Plugs (AWSF32EG in cylinders 1-2-3-4 ) (AWSF32E CYLINDERS 5-6-7-8)
With all the spark plugs in and properly gaped (In Neutral) I noticed a slight delay in throttle response and a little sputtering. Under load in drive I could hear a small back firing from the exhaust..It ran terrible, it strained for power on the highway I was better off with the old worn out plugs installed. I understand that exhaust back firing is an indicator of bad exhaust valve/valves. It never back fired through the exhaust before the spark plug change and had power to spare with the old worn plugs.
The only thing I noticed was cylinders 1-2-3-4 used Motorcraft AWSF32EG and cylinders 5-6-7-8 used Motorcraft AWSF32E
Any information will be very much appreciated.
Thank you,
Rick
Thank you,
Rick
