Mike65
- December 31, 2013
- Horsepasture, Virginia.
- 00 Ranger 4x4, 99 Sport.
Last weekend I removed the headliner in my wife's 99 Sport & today I removed the sunroof glass, the water catch pan, & the sliding sunroof shade so I could recover it. I used a putty knife to remove all the old foam from the cover then sprayed a couple coats of 3M Super 77 spray adhesive that ?I purchased at Lowes. I purchased the replacement headliner material from E Bay. I measured the size of the shade & cut the material a couple inches larger all around the shade. I rolled the material up with the side going to the shade facing out, & started from one side & rolled it out on to the shade working out any lumps. Once I got all 4 sides glued I made finish cuts on the material & cut the hole for the handle that just clips into the shade on my 99, be careful not to break any of the tabs. One of the tabs broke on the handle on reassembly so I used some super glue on the back side to make sure it stays in the shade. I reinstalled the 4 slider clips on the shade that allow the shade to slide in the track, & reinstalled the shade to the sunroof assembly, & reinstalled the water catch pan. I then reinstalled the sunroof glass & left the bolts a little loose & pivoted the back of the sunroof up & pushed up on the back of the glass, tightened all 6 bolts (3 each side), & then operated the sunroof open & closed to verify operation & that the sunroof glass is flush with the roof.
Here are the 3 sunroof glass bolts
Here is the trim that covers the bolts installed
Here is the recovered sunroof sliding shade
Here is the shade installed back in the truck
Now I have to reinstall the headliner & button everything back up.
