SoNic67
- January 24, 2010
- Newport News, VA
- 2001 V8 (Eddie Bauer) AWD
And WHAT causes the LOW side pressure value? Heat.
On manual A/C, will be determined by the amount of heat that you will extract from the car, via evaporator coil. That is based on the delta temperature.
More extracted heat (lower cooling setting inside compared to outside temperature) means bigger delta T, will drop the pressure more, forcing the compressor to run longer to re-create from that LOW back the HIGH pressure.
Is not the same work to go from 30 to 220 psi as from 60 to 220 psi.
On automatic A/C, the red button or settings on dial creates a set-point for inside temperature. When that is achieved, the compressor is turned off. When temperature raises past the upper limit, compressor is on. How often depends of the heat resistance of your car and delta T. Bigger delta T (for a given car thermal insulation) will make compressor work longer.
Lower pressure side switch will cut-off the compressor when pressure drops very low. Like when is not enough refrigerant. A/C pressure testing gauges are cheap.
