thejoker954
- January 21, 2009
- 96 EB
Hi all I've got a 96 EB. I'm having trouble with the a/c system (EATC if it makes a difference). it only blows coolish air. not cold. Having done some research on here I have checked the following;
1. recirc door (works)
2. Temp blend door actuator (works)
3. temp blend door (works)
4. level select [defrost,floor,vent,etc] (works)
5. heater core cutoff [vacuum line works, adjuster arm works, not sure of internals]
on the low side port with my truck off I've got high pressure (in the red on the cheap gauge that come with a recharge can. if I recall correctly it was around 100 psi but could be way off) with the truck on, but compressor not engaged it's in the green - about 45 psi.
but as soon as the compressor kicks on it drops to about 20 psi and shuts off the compressor.
will add more later....
