runningred92
- April 12, 2011
- Nashville,TN
- '92 XLT
Ok so my system has been retrofitted to accept R-143-a by the previous owner and about this time every year I need to recharge the system. I bought a can of R-134-a and went to recharge it. With my truck running and a/c on high I hooked up the hose with an in-line pressure gauge to the L port and instead of being low it was at 100psi. UHOH! I left the air running on my way home and noticed that when I am moving the air blows at least 20 degrees cooler but as soon as I stop it goes back to blowing HOT. My dummy temp gauge on the dash is normally below the N and with the air running it moves almost to the N. Now I know the engine is at a good operating temp I have had it checked so as long as it stays right there I know its ok. Is my compressor not running correctly or??? I know a little about a/c systems but could use some help with this one. Could it be as simple as just removing coolant to proper operating pressure? Appreciate some help with this one.
-Andrew
-Andrew
