sqhurt
- December 10, 2007
- ohio
- 93 sport & 4 door
Have a 93 4 door explorer 4x4. Just put a 97 motor in it an wanting to get the ac working. The light comes on when a/c is pushed on. I used a jumper wire on the pressure switch an the comp. finally kicked on. I added a can of 134a but noticed i forgot to put the lil tube back on the hole from the comp. line to the comp. so figuring it went straight out that. But was wondering how do you do a pressure test on the a/c unit/lines to make sure all leaks are taken care of before spending more money to have the freon leak out? Thanks in advance
