Lemme get this straight...
OK, so I'm using the wal-mart special can to recharge my AC (95 MY, r134, auto climate control). I see 2 fittings in the AC system... one atop the accumulator (black, passenger side near firewall), and one inline with the hose running from the compressor to the condensor (near the battery, driver's side). I was led to believe that the fitting on the accumulator would be the "low pressure side", AM I CORRECT?? If so, I tried recharging per the instructions (can inverted, A/C on MAX, warmed engine)....
It seemed it took only a small part of the can, and the rest started blowing off where the valve meets the can of recharge coolant (not sure if it's a pressure relief valve built into it or if it just blew the seal). I worked with it for about 10 minutes, and that's all it took. AC doesn't feel any colder, compressor clutch still cycles incessantly.
Haven't noticed any leaks. Am I doing this wrong? Thanks for your help in advance, just looking for clarifications based on previous posts. 174K miles now just for useless info....
