BWTGUY
- April 26, 2010
- La Crescenta, CA
- 92 Eddie Bauer 4X4
I finally worked up enough courage to open up Bebe's (my BrownEddieBaurExplorer) front end and start the ball-joint, brake, and front drive universal replacement.
Of course Cap'n Murphy and his law functioned flawlessly. Everything came apart with ease until the point I tried to remove the Knuckle on the right side and the lower ball joint would not cooperate. OK, I sprayed the ball joint with PB Blaster and beat the hell out of it for an hour and a half. NO SUCCESS.
I decided I'd just replace the outer U-Joint while the PB Blaster worked.
I removed the c clips in the joint (the inside the U-joint C clips) and tried to press out the U-joint. No-Joy! The U-joint will not move even though the clips have been removed. A magnifying glass look at the joint shows no other clips.
Am I just having a bad hair day or is there something I don't know about the ball-joint and U-joint removal. HELP!
Anybody?
Anybody?
