andymorgan21
- July 19, 2007
- Kelso, Wa.
- 91 xlt
This last weekend while driving my 91 exlplorer it started leaking tranny fluid. I pulled over and noticed there was fluid on the cross member and around the front of the transmission. I had no tranny fluid to add and no cell phone service. So i drove it as easy as i could (10-15mph) till i was off the mountain and got some tranny fluid and took it to my brothers house. We filled w/ fluid and took it out. It would only manually shift from 1st to 2nd but in D and OD it felt like it was slipping and then when the speed was slow enough it would go into 1st. It would not leak anymore, so i changed the filter and fluid, but still no luck. 1st, 2nd, and reverse seem to work fine. The old fluid was a dark red and smelt a little burnt. After new fluid and filter i test drove it and still would not shift but started to smell hot. I was told the burning smell could be from putting it into drive and the tranny trying to go into 1st. The test drive was only a 1/2 mile or so. Also on the back of the gas pedal the cable to the kick down had a spring on it but it had an inch of slack in it. Is there supposed to be a spacer? It functions with a home-made spacer so i dont think the cable is broke. It still doesnt shift in D or OD, Any ideas?
