wood1
- May 3, 2007
- North of Edmonton
- '93 XLT, Cayman Green RIP
Hey guys,
I have a basicly stock '94 XLT 4dr, 295,000 kms on the origional A4LD trans and engine. I did a fluid change and filter this past summer and all was well.
This past Friday I discovered that the torque converter clutch wasn't locking.
I figured that I'd look into it in a couple days after I had a chance to re-read some threads.
Late Friday night things took a turn for the worse. On the way home from work my trans wouldn't shift out of 1st. I had the selector in drive ( D ) not OD. I let it rev a bit and let off the gas but it still wouldn't shift out of 1st until I selected 2nd with the gearshift lever. I live close to work so 2-3 minutes later I was pulling into my driveway wondering if this was IT.
The fluid is nice and red, not burnt and the level is good. I pulled some fluid out through the dipstick tube with a suction gun and ran it through a coffee filter. There was no signs of any metal in the fluid.
I have done a few searches but everthing I read points to two probable seperate issues. Governor or modulator for the shifting issue, and a TCC solenoid electrical or mechanical failure (plugged screen).
I checked the modulator vacuum line and there isn't any fluid in it, also the fluid level in the trans is good so I have my doubts that it is the modulator.
I took it out for a drive today and at first the trans wouldn't shift out of 1st, but after a couple seconds everything went back to normal (except the TCC), trans shifting perfect. I have engine braking when I select 1st and 2nd and shifts seem normal.
Any suggestions on what to do now? I will be pulling the TCC solenoid out to check it within a couple days so I'll have the pan off anyway.
I have been expecting a rebuild but I'm hoping it's not time just yet...
Thanks,
Chris.
Thanks,
Chris.
