organman
- December 19, 2006
- Whiteville NC
- Ranger 92
Seems a4ld's have some issues which brings me to this. One morning my 92 Ranger 4.0 would not go into OD. Later that day tranny seemed to function ok. Two days later trans would not shift above 2nd, then noticed I had no reverse. Checked fluid level, OK. Dropped pan changed filter, cleaned pan and replaced, no change. All trans guys talk rebuild, I don't want to go there if possible. Tried and experiment. Disconnected vacuum line from modulator, and plugged the vacuum tree at the motor (so motor would run properly). Guess what? Reverse began to work. Replaced mod (it was bad) fired the truck, reverse engaged, backed out of the drive and went for a drive. Trans shifted smoothly, but still no OD. Drove home and now no reverse. Tried the experiment again, Reverse. Any info in this situation would be greatly welcomed.
