johnwartjr
- December 28, 2009
- Columbus, Indiana
- '96 Limited
I had both front hubs replaced about a week ago, as the left side wheel bearings were getting uber noisy and it just made sense to replace them both.
Before the hub replacement, I had the following code:
B1194 ABS $28 Antilock Brake System Outlet Valve Coil Left Front Circuit Malfunction
I cleared it at Advance, and it went away for awhile. 2-3 days, and it came back.
After replacing both hubs, I now get the same code, plus the one referencing the right side.
B1210 ABS $28 Antilock Brake System Outlet Valve Coil Right Front Circuit Malfunction
I clear them, the code reader says they are cleared, and they return immediately upon turning the key to accessory - I don't even have to crank the engine!
I checked both ABS relays in the box behind the battery upon the advice of the guy at the parts store - and they are both fine.
Where should I look next? It's the last trouble code on the wife's explorer, and I'd love to be codeless
