rwenzing
- November 18, 2005
- Michigan
- 03 Ranger FX4 LII 5.0 S/C
98~2001 Explorers take the raw VSS signal from the rear axle and do the speed correction in the 4WABS Module before sending the corrected VSS to the speedo and PCM. So, if you choose to power down the ABS Module by turning off the circuit from fuse #14, you will lose the speedometer/odometer. You might also get a CEL w/fault code P0500.On a 98, will this throw the CEL on and will I lose the speedo/odometer? Again, for a 98.
95~97 have a completely different VSS arrangement, independent of the 4WABS Module. For these years, the speedometer would continue to operate with 4WABS disabled.
