hillbillybuddha
- November 28, 2012
- Sacramento, CA
- 1994 Explorer Sport 4WD
Just bought a 1994 Ford Explorer Sport 2WD Manual Trans (M5R1) It has a few issues that I'll be addressing one at a time (hopefully with the help of this forum)
Yesterday I decided to change the front brakes. I was squeaking a bit and I could feel the ABS rattling in the brake peddle even with very light braking. After getting the wheel off, I discovered both that pads and the rotors were F'ed up. The pads were down to metal and the rotors had a ridge on the outside lip about 1.5 to 2mm. There didn't seem to be much rotor left.
Well, I had the pads but I didn't have the rotors; I wasn't about to put those old pads back on and my girl had the other car, so I put the new pads on, ran to Autozone, bought new rotors (guy asked if it has ABS because I guess it's different rotors but If I'm NOT mistaken the 94 and earlier Explorers only had rear ABS??? But I got the rotors for ABS and they look exactly the same as the old messed up rotors I removed), inner and outer bearings and seals and a few quarts of DOT3 because the fluid was the color of old, strong Turkish coffee.
I guess I should say here that the brakes basically acted the same as before I changed them but were a bit more responsive and the truck stopped pulling to the left during braking (I don't believe it was an alignment issue)
Got home, pulled off the new pads and old rotors; Flushed the brake fluid but after 3 full quarts could only get the color from thick dark reddish coffee to watered down iced tea. Huge improvement but not perfect. Cleaned up everything; packed with high temp grease; fitted new seals and put everything back together.
Now I'm having issues. I drove it around the neighborhood and braking became really hard and very loud. When pushing the brake pedal it freezes up and only goes about a half an inch down or so and you can hear and feel the ABS kick in very loud thud thud thud and a hydraulic whining before it softens up and pushes to the floor in a somewhat normal manner. Pumping the brakes made no noticeable difference. It's almost like the ABS is fighting me braking and then gives up and turns off and allows me to brake. The yellow ABS light turns on as soon as the ABS system gives up and lets me brake...
Alright guys, I'm all ears. I've got a code reader I bought for my 91 Bronco that should work on my Explorer once I research how to do the KOEO and KOER tests for this truck...
Anyway, This is going to be my Daily Driver so my girl doesn't have to drive me around... So I could really use suggestions.
Thanks,
Joel
Thanks,
Joel
