tonydmm2
- November 10, 2012
- 2005 Ford Explorer
Hi All,
2005 ford explorer xlt v8, 140k miles.
I'm having a problem where when I turn left slowly the car makes an awful grinding sound. I'm pretty sure its an ABS problem.
This all started last year when I replaced my wheel bearing assemblies that came with new abs sensor cables. It started after about 50 miles, when I pulled into the parking lot, it made this awful grinding sound. It was intermittent for about a year, it slowly got worse. Just recently the traction control light started illuminating on left turns and the car would just die in the middle of the turn. I finally measured the ohms on the Precision branded Napa purchased speed sensor, it showed 4.5 mega ohms. Napa replaced this under warranty, (with 1 day left on the 1 year warranty, lol). but they made me get the whole wheel bearing assembly. I paid an extra $90 for the upgraded assy, SKF brand with a 3 year warranty. I tested the resistance on the new one and it showed an open circuit, I assumed that my test meter was bad, so I installed it anyways, and sure enough, the abs & traction control problems were worse than ever. So I went back and got another replacement, it shows 2.1 mega ohms, I think 1.5 mega ohms is supposed to be normal, but I installed it. The traction control problem is gone, but I'm still getting the abs grinding sound during the left turns.
I purchased some scanner software and it was displaying the 4 speed sensors speed while driving, they all show good data up to 80 mph, but during the slow left turn at about 15 mph the grinding noise occurs, all 4 sensors went to 0 during the problem noise. (It also shows the abs module with no error codes).
I'm thinking this indicates a bad abs control module or a short in the circuit, because all 4 sensors went to zero during the slow left turn malfunction event.
Any suggestions? There's like 200 parameters associated with the abs module, but I'm not sure which ones to monitor.
