don blaze
- February 25, 2014
- 2007 ford explorer lmtd
I have a 07 limited with these symptoms abs,traction control and wrench lights coming on .....go about ten feet right front wheel locks up. Just changed drivers side front wheel hub assy thinking this was the problem ..... right wheel hub seems fine no movement or noise. Hooked computer up to vehicle and code C1234 came up? Which if for abs sensor my question is do need to replace whole hub or just the abs sensor wire?
