Abs/stability control light | Ford Explorer Forums
wkeene
Clarksville
2013 Ford Explorer Limite
This is on a 2013 Ford Explorer Limited two-wheel drive... The ABS and stability control lights are on, both of the rear speed sensors were replaced. Both of those sensor wires meet in the middle to a cluster of wires and a harness, you can see after unplugging the harness there is corrosion and one of the pins is broken... I went to the Ford dealership and he pulled it up on a schematic and showed part DB5Z14a411C shows that listed as some type of wire jumper harness harness. Was wondering if anyone had any experience in replacing this harness and could save me some headaches.. this is on my son's vehicle I appreciate any help and thanks for allowing me the opportunity to post.
