LMAO!
Anyways, Alright Rudy... Cut your seatbelts out, remove your airbags, and cut every wheel speed sensors... while we're at it.. lets remove both bumpers and your windshield. How about we just remove the brakes completely?
You are drawing this out way too much, this is ridiculous. You need to stop.
I've had experiences when ABS pissed me off, and where ABS had my truck stopped not even 1/4 of an inch away from a pole when I Know for a fact I would have been wrapped around it if I had my ABS de-activated.
I live in Alaska out of all places, try that on for size... our roads are already crap, add ice, black ice, freezing rain.. ect.. why not throw in some fog and heavy snowfall for zero visibility on a 361 mile/6 hour trip. Yay, that's always fun. I KNOW first hand how driving on absolute **** can be like. ABS has saved me a lot of damage, pain, money, ect... while at the same time, has gotten me into a few messes. It's not perfect, but it has it's application under certain/most circumstances.
What exactly is your problem here? You sit there and second guess the by-pass I told you about and yet you just wanna pull the bulb... ignorance isn't an excuse and that's exactly what they will tell you when you get inspected. With a bulb pulled, doesn't mean the problem is gone. You think just because your light isn't on they won't know? This is the age of computers my friend and it will tell them every single thing you're trying to hide. Do it right and make an actual bypass, you can turn it back on that way. And I hope to god you turn it back on for winter use, watch as you get into an accident because you refused to solve your ABS issue, guess what... you'll definitely be more prone for an accident without it, and have fun with getting sued once they found out you purposely got rid of it simply because you don't like it.
Here... try this... when winter hits... go to a big empty parking lot.. and buy some cones and some paint. Do the bypass like I explained and come back here with your own personal results.
I want stopping distance with/without ABS.
I also want a detailed explanation of how dodging an obstacle went with/without ABS.
Can you do that? I'm serious, do some tests and see what happens. Good luck trying to regain control of the rear of your truck as it swings right back around at you.
Hell, go try it now. Your ABS should be turned off if the light is on. Find some gravel road and slam on the brakes... see how fun that gets. Pretend a moose just walked right out in front of you. Which actually just happened to me.. I managed to dodge it.
Question; how would you react to a moose walking right out in front of you on ice? You'd most likely hit the moose with ABS off if you had to dodge it and you used your brakes.
I don't know about the rest of you but gas is more of my friend than brakes are in the winter, it all depends on how you're gonna attack the situation.
This whole thread has my thoughts all jumbled up because you just want to fight every single person who comments. Is there anything you'll listen to?
