AC causes RpMs to go down?
kyleb617
Everett, MA
1999 XLT
When im Idle and have my AC on my RPMs decrease and it feells like my engine almost stalls. What could be the problem? When I drive its cool as ever but idling tends to blow out semi warm air
njlegion
West milford nj
1999 sport
I actually have the same problem, except mine actually stalls almost everytime i start it with the ac or heat on. Though it seems the problem gets worse in the cold. Ive actually taken it to a shop twice to no avail, If anyone has any insight that would be great
herebyproxy
Luthersville, Ga
2000 Sport
REPLACE the IAC
9 times out of 10 cleaning it will not help....just go ahead and replace it. They aren't that expensive.
M Common causes of wind noise Stock 1995 - 2001 Explorers 0
K Wondering what causes it Stock 1995 - 2001 Explorers 5
B Solved What causes excessive inner tire wear? Stock 1995 - 2001 Explorers 15
M T/S causes buzzing right turn position Stock 1995 - 2001 Explorers 14
J What Causes Battery Light to Come On Stock 1995 - 2001 Explorers 28
9 What causes speedo/tach needles to return to 0 Stock 1995 - 2001 Explorers 9
J Causes for 99 Mountaineer 5.0 overheating? Stock 1995 - 2001 Explorers 5
B Oil Pressure Gauge causes stalling????? Stock 1995 - 2001 Explorers 16
J What causes a tranny housing to crack? Stock 1995 - 2001 Explorers 6
T Bad O2 sensor causes stalling at idle? Stock 1995 - 2001 Explorers 7
9 Carwash underbody spray causes surging, 02 Sport - also front dif pinion seal questio Stock 1995 - 2001 Explorers 1
9 Running lean -100 on bank 1? Possible causes? Stock 1995 - 2001 Explorers 13
X Causes of needing a wheel aligment Stock 1995 - 2001 Explorers 13
D Causes of "Check engine Light" NO FAULTS Stock 1995 - 2001 Explorers 5
I What causes the rear to sag on Explorers? Stock 1995 - 2001 Explorers 1
L rain causes P0446 code? HELP!!!!! Stock 1995 - 2001 Explorers 3
B Causes for a P0174 Code? Stock 1995 - 2001 Explorers 62
C what causes rear hatch to pop out when button is pushed? Stock 1995 - 2001 Explorers 1
A Wheel bearing shot ? Other causes ? Normal ? Stock 1995 - 2001 Explorers 15
B What causes uneven plug wear? Stock 1995 - 2001 Explorers 8
H Turning wheel at standstill with brake applied causes vibration Stock 1995 - 2001 Explorers 9
R What causes Error Code 214-Cylinder Identification Circuit Failure? Stock 1995 - 2001 Explorers 1
E help - occasional highway RPMS surge to 4200 but Speed only 60? Stock 1995 - 2001 Explorers 10
M RPMS surging on acceleration Stock 1995 - 2001 Explorers 3
T Coolant leak repair > missing at all RPMs Stock 1995 - 2001 Explorers 12
N When the explorer is heated, started hesitating acceleration with high rpms Stock 1995 - 2001 Explorers 35
B Rough idle and wont tack up past 3000 rpms. Stock 1995 - 2001 Explorers 0
S RPMs hang, won't shift. Stock 1995 - 2001 Explorers 3
K No Power past 2500/3000 RPMs Stock 1995 - 2001 Explorers 9
dlphnfn Surging, sputtering, loss of power at idle and low RPMs when HOT Stock 1995 - 2001 Explorers 5
Z Bouncing oil pressure and drop at higher rpms Stock 1995 - 2001 Explorers 15
F 99 4.0 sohc wont exceed 2000 rpms Stock 1995 - 2001 Explorers 19
G how many rpms at a stop light Stock 1995 - 2001 Explorers 8
C 00' mounataineer 5.0 pulsates at low rpms? Stock 1995 - 2001 Explorers 2
J Rattlely sound in upper rpms? Stock 1995 - 2001 Explorers 12
S poor MPGs/High rpms.. Stock 1995 - 2001 Explorers 4
B 97 Sport hates 1800 rpms Stock 1995 - 2001 Explorers 4
A Hesitation/sputtering during acceleration from low rpms. Stock 1995 - 2001 Explorers 1
B RPMs dropping when turning defroster on full blast. PLEASE HELP! Stock 1995 - 2001 Explorers 13
B Wont rev over 1500, 2000,2500, or 3000 RPMS Stock 1995 - 2001 Explorers 5
B high rpms Stock 1995 - 2001 Explorers 3
P Funky hesitation 1000 rpms or lower Stock 1995 - 2001 Explorers 2
C RPMs drop accompanied with a whining noise Stock 1995 - 2001 Explorers 8
B Will not rev past 3000 rpms Stock 1995 - 2001 Explorers 4
S No power steering at low rpms? Stock 1995 - 2001 Explorers 4
D My 4.0 SOHC does not go over 3k RPMS Stock 1995 - 2001 Explorers 1
E Explorer is making a tick then reving up 5k rpms? Stock 1995 - 2001 Explorers 5
D 2001 Ford Explorer Sport Auto RPMs? Stock 1995 - 2001 Explorers 5
S Idle problems after warm up, RPMs rise when the brakes are pumped. Stock 1995 - 2001 Explorers 4
R Rattle at low RPMS after changing serp belt Stock 1995 - 2001 Explorers 1
Similar threads
