Gatemann
- January 16, 2008
- British Columbia
- '94 Explorer,'86 Ranger.
Ac recharge
Hi,I just did mine today and I used the whole can of Glacier Ice 18 onces,It cycled off and on with pressure from about 15(compressor off to 60 compressor on) I kept adding untill the cycling stopped and the pressure steadied at 35 or 40 this took about 15 minutes and now its working great.
Same Problem.
A/c didn't work at all, so I added about 3/4 of the 18 oz can. the pressure while running and the a/c on is 47 PSI then the compressor clicks on, slowly drains the pressure down to about 19lbs, at which point the compressor stops, the pressure builds back to 47 PSI, repeat. I thought I must need to add more, and I probably do, but if I turn the truck off the pressure read 125 PSI. Is this O.K.? I didn't think the pressure jumped up so high when the truck wasn't running.
the 134a I added has lubricant in it.
