Solved - AC oil amounts | Ford Explorer - Ford Ranger Forums - Serious Explorations
Solved AC oil amounts
Jason94sport
FL
02 Sport 2WD 5 speed
Replacing all the AC stuff this weekend. Compressor blew, black death. The new compressor has 7oz of pag-46, how much do I need to add to the condenser, accumulator, & evaporator?
Rich52490
Chicago, IL
94 XLT
7 oz of PAG-46 is the total amount for the entire system :thumbsup:
Jason94sport
FL
So do I need to take some out of the compressor & add it to the other items? Or will it circulate through the system once it's charged? These are all new parts. The compressor came pre oiled.
4x4junkie
So.Calif.(San Fernando Valley)
'94 Ranger, '90 Bronco II
No need to redistribute it.
Be sure to give the compressor (clutch) a number of spins by hand in the proper direction after you close up the system and again just before you evacuate & charge it. This will push any excess oil out of the compressor that could otherwise damage it if it's first engaged at engine speed. After that it should distribute itself throughout the system.
Jason94sport
FL
Cool. I did add just a little to the accumulator. I spilled a little out of the compressor mounting it.
thanks
