- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Couple of things
If your compressor is short cycling and you suspect it’s low on refrigerant, we jumper the low pressure switch. If compressor stays on then you know you found your issue
Low refrigerant
Same Goes for the high pressure switch
If it is short cycling due to excessive pressure
Buildup then jumper the high pressure switch to confirm
Always clean or replace the orrofice tube when serving the system
I have had good luck with 4 seasons aftermarket parts. All compressors ship with the note “this compressor shipped dry blah blah… but our style compressors always come charged with oil which is quite obvious when you unbox it and see the plug on the back
The 5.0 charge is 30-34 oz almost exact same charge as sohc engine
The high and low
Pressure port schrader valves are often the source of small leaks. I’ve had good luck repairing them by taking it apart and cleaning. Or replace the little valve with parts FromDonor truck
Junkyard find a good dual
Core radiator and flush that sucker out. Prices for new are ridiculous and the parts are usually crap
The fully tig welded all aluminum units on eBay are hit or miss I’ve had them last 5 or 8 years and two of them less then a year before leaks develop…
Low refrigerant
The high and low
