yeahokay
- May 11, 2023
- Colorado
- 1999 Explorer EB 5.0
Bought a 99 5.0 EB AWD a few months ago, originally had a miss replaced camshaft position sensor and alternator and its ran smooth since then. Last week took it on its longest trip since buying it. 60 miles one way 60 miles back, 20 miles (on the way back) from the house it lost all power on me, before it lost power there were some misses but nothing major. Moved to the shoulder and checked everything I could. There were no check engine lights to help, the engine never died, but in neutral i couldnt even rev passed 1500rpms and it was backfiring. Called tow truck which took forever, and before the tow truck got there I started it back up and it was like nothing happened. Ran smooth. Went ahead and got the tow.
I figure this is an air/fuel/ignition issue. I verified there was no blockage in the air intake. Pulled a plug on both sides, they are not original they are ngk but do not look good looks like they had been exposed to high temps. Im 90% sure the wires are original as they are motocraft and have a date code of 1999.
So I have ordered plugs, motorcraft wires, fuel filter to get started with. I plan to check fuel pressure but i doubt i will see anything while its running well, so I plan to replace the fuel pump but i want to do more tests. I also ordered a better scanner so I can check misses and fuel trims. Last I plan to clean the MAF IAC and throttle body although I doubt that was the issue in this case.
Any idea what else I should look at? The lack of codes is perplexing that it could have that big of an issue without a code, but who knows.
