MM07
- January 13, 2019
- MA
- 2018 Explorer Limited
I have posted my alleged issues in another thread, but I wanted to ask for some help separately.
I feel that my chimes are not working correctly. Let me explain...
When I start the car and before I put on my seat belt (and open the door when the car is on) that chime comes from the IPC. Is that normal?
When I pull forward and come close to something the chime comes from the IPC.
When I reverse and get close to something the chime comes from the IPC.
When I am in reverse and someone comes in range that chime comes from the IPC.
I know most of those are wrong. I remember hearing sounds come from the speakers in most of those cases. I noticed this maybe in July and have been going crazy trying to figure it out.
I have reset modules in FORScan, looked for DTCs in FORScan...nothing. Yes I upgraded to SYNC 3.4.
The other day I installed a new 750 CCA AGM battery. Today I fully charged that with a charger.
The sounds remain the same.
I am asking that if you have an 18 EXP that you let me know how exactly the sounds work for you. I guess it doesn't matter if it is an 18, maybe just a 5th gen?
Thanks for your help guys.
