Add a Leaf | Page 4 | Ford Explorer Forums
Add a Leaf
I know that people have drilled out the AAL holes... others have installed them but i wouldnt trust the small bolt. The double kit comes with a thicker bolt.
Good luck drilling.....thats your best bet
Update:
Well I called a machine shop yesterday and they said that they couldn't do it but reffered me to another shop that could... I called them and they said they wouldn't... They reffered me to a place called Denver Spring, that is all they do is springs... So I called down there and spoke to a lady and said that they'd just charge me real time shop rate... $65 an hour, but that I would be having it done at my on risk that they might crack or brake... So I took them down there, she looked at them, took one in the back and the guy said no problem... I gave them the size of bolt that had to fit through there and they came back about 10 or so minutes later... Total charge was $11.25... Not bad if you ask me... No hopefully they'll go on okay this weekend or whenever I can find the time and friends to help me get them on there...
Any reason you didn't drill them yourself?
Summit Racing Price 4/7/03
$117 and currently on back order until 4/19/03
Thats for the Double
Double AAL
No problem on a '97 4DR?
I currently have the (looks like 4 leafs) but I think it's one leaf with 3 things under it.
I've called many places and asked many people and nobody knows. I've ordered too many '97 parts that end up not working.
Re: Double AAL
It should work fine. All 91-2001 4 Door Explorer leafs are the same.
Not exactally true. Replacement leafs are the same, but stock there were several different types. According to one place I went to they showed me a book which showed several different options for leaf springs and mine weren't the stiffest, but gave the most lift.
He said that the website I reffered to might be assumeing that most explorers will have a single or tapered leaf?
I'm still not sure about all this. Just know the rear needs 1-2"
any one else make double aals
who else makes em cause my local 4x4 shop doesn't carry pro comp and i don't wanna deal with ordering online and haveing them not work??
does trailmaster rancho superlift make any??
i need a double leaf for a 4 door leaf packs on a 98 sport.
i'm not sure what year X the leaf packs are off of.
will the add a leafs fit if i get some made for a first generation x?
After reading about how the bolt holding the leaves together can shear off under stress I'm a little concerned. Is this only a problem if the bolts aren't tightened to the proper torque? The numbers I've seen are 80 ft-lbs for the bolt holding the leaves and 95 ft-lbs for the bolts on the U-brackets.
