ADDCO anti sway bar | Ford Explorer Forums - Serious Explorations
ADDCO anti sway bar
turbojim
Hanover, PA
'04 Sport Trac XLT
anyone here ever used Addco front sway bar? What kind of shocks are recommended to help firm up ride a bit? Lastly, will 20 inch wheels fit comfortably?? (04 sport trac XLT)
Welcome to the site.:chug:
I moved your post to our Suspension and Shock forum.
i believe 97sandbox has used them. as far as shocks KYB monomax bilstien the yellow ones or whatever were great in my experience. air shocks are adjustable, but idk if they just fit normally w/o extra work.
The Addco 2nd gen Explorer front bar is 1.5", and the frame bushing brackets were unusable when I bought them in 2006. I had new brackets made by a machine shop that fit the bolt heads properly.
I suggest trying to work in rubber end links if you can find them large enough to survive long term. That bar is a bit stiffer than the OEM 34mm bar. You definitely will need a much bigger than stock rear bar, the old EE bar at 1.125" is almost big enough.
