Fixedgear74
- May 28, 2017
- Lake Tahoe, CA.
- 1994 Explorer XLT 4d 4x4
This is for a 1994 Ford Explorer, running the stock 4.0L engine.
I have dug around the forum and read what I could but wanted a second opinion from you all before I go ripping into this project.
I want to put in aftermarket ISSPRO EV2 gauges (Coolant temp, Oil Pressure and Volt meter).
I am also doing a Transmission Temp gauge/sensor set up.
When you all have done the Coolant / Oil sensors did you use the existing ports that the stock dumb dash gauges are hooked up to.
I just don't trust the stock dash gauges anymore and since this is becoming more of an off-road rig I want to know whats really going on.
The gauges I have figured out (Coolant / Oil / Volt are going on the A pillar and the Transmission is going in a steering column pod)
Any feedback would be greatly appreciated.
