PontiacMuscle
- March 13, 2007
- Milwaukee, Wisconsin
- 1993 Explorer XLT
Im trying to install an aftermarket radio in my 93 XLT but heres the problem.. No sound.. All the wiring for the power is correct and if i hook up a loose 6x9 up to the wiring for the speakers i get sound but if i connect it to the factory harness plug i get Nothing !! stock radio works fine ! all connections are good IE no opens or shorts Ive checked them with my meter ! ive taken the pins out of my aftermarket connector and tried inserting them into the factory plug individually but no luck... i have 2 connectors on the factory side the large retangular side and small square 8-pin !! the 8 pin appears to have some type of shield on it, so i tried grounding it out.. still nothing.. what am I missing !?
Thanks
Scott !
Thanks
Scott !
