Air conditioner duct problem
Tirepro
Clermont
2004 Ford Explorer
Air is cold. I can hear that the blower motor is blowing strong, but air is not coming out of the a/c vents properly. Any known problems.?
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
Bman505
2005 Sport trac
I have the same problem.
2006 sport trac - on day ac was running and then "bang" and all of a sudden i had very little air flow out of the vents, the fan speed did not change but makes one heck of a racket.
i can switch between vents and defrost just very little air flow.
jimborasco
middle of nowhere in the mountains of southwestern VA
2003 Explorer
I'm having the same problem with my 2003 explorer. Passenger side has strong air flow, driver's side vent barely blows, the center ones blow a bit. I've fiddled with the door behind the glove box last winter (had the cold air flow problem from that) but now I'm having trouble with the airflow in those vents. I'm guessing I'll have trouble with the cold air again this winter. Anyone have any other suggestions? I'd sure love to hear them. This is getting to be a real pain.
artest7
Bellevue, Wa.
2001 Eddie Bauer
I'm having the same problem too! Blend door and actuator work. I believe it may be a vacuum issue on the "other" actuator(s)(ie. defrost/flr/etc.) Did you resolve the issue yet?
jimborasco
2003 Explorer
@artest7, I'm still fighting with mine. The dang thing will take spells of blowing a little more from the driver's side vents once in a while, but it never lasts long. The fan noise when turned to high is deafening. I've taken the cowl off (under the windshield) and where there is supposed to be a vent for outside air, I don't have one! Now that cold weather is coming, I'm having trouble with the cold air blowing through the glovebox again. I've worked on it once, with a bit of success, but it seems that problem is back again too. *smh*
artest7
Bellevue, Wa.
2001 Eddie Bauer
Did you test all your vacuum lines, actuators and Door Vacuum Motors?
R 08 explorer air conditioner help A/C & Heater systems - HVAC 10
D Air Conditioner Compressor A/C & Heater systems - HVAC 4
S Air conditioner problems. A/C & Heater systems - HVAC 1
B Broken air conditioner. A/C & Heater systems - HVAC 1
U Air conditioner noise. A/C & Heater systems - HVAC 2
Z Air conditioner issues. A/C & Heater systems - HVAC 1
1 96 Explorer air conditioner blower. A/C & Heater systems - HVAC 1
C Air conditioner rattling A/C & Heater systems - HVAC 17
R 2002 Ford Explorer air conditioner problems. A/C & Heater systems - HVAC 2
Tarpman Air Conditioner Growl A/C & Heater systems - HVAC 1
C Air Conditioner on Highway hot? A/C & Heater systems - HVAC 6
P 1991 explorer air conditioner question A/C & Heater systems - HVAC 3
G How to: Converting an R-12 Air Conditioner to use R-134a A/C & Heater systems - HVAC 119
P '15 Limited blowing warm air - fans not turning on A/C & Heater systems - HVAC 0
S Rear AC not pushing out air A/C & Heater systems - HVAC 0
G 2013 A/C No cold air A/C & Heater systems - HVAC 2
M Diagnosing A/C - Blowing Warm/Hot Air A/C & Heater systems - HVAC 2
A No air blowing out of front vents, defrost, floor. Vacuum Reservoir(Plastic globe) is disconnected A/C & Heater systems - HVAC 17
H Air Conditioning A/C & Heater systems - HVAC 2
J Air Compressor "Siezed UP" A/C & Heater systems - HVAC 9
Y 98 explorer won't blow cold air! A/C & Heater systems - HVAC 0
A heat stop blowing warm air A/C & Heater systems - HVAC 0
C '97 Always hot air, NOT the blend door????? Please help A/C & Heater systems - HVAC 8
R Too Much Air Conditioning A/C & Heater systems - HVAC 2
D 99 Explorer Sport A/C Blowing Hot Air A/C & Heater systems - HVAC 1
B HVAC Air Temp A/C & Heater systems - HVAC 1
P 02 Explorer - Air/Vent control won't work A/C & Heater systems - HVAC 0
A Explorer Air Box into a Ranger? A/C & Heater systems - HVAC 0
College Student Adding rear air A/C & Heater systems - HVAC 3
P No cold air/compressor problem?? A/C & Heater systems - HVAC 1
O Air vents have a clicking noise. A/C & Heater systems - HVAC 1
Q A/C Blowing Hot Air (surprise!) A/C & Heater systems - HVAC 1
M ac stops bloing cold air A/C & Heater systems - HVAC 5
S Low air from vents A/C & Heater systems - HVAC 2
P A/C not blowing cold air A/C & Heater systems - HVAC 3
C A/C blowing hot air A/C & Heater systems - HVAC 0
E 2005- no air/heat from vents - only defrost & floor A/C & Heater systems - HVAC 3
S Not very cold air A/C & Heater systems - HVAC 0
P 2005 Explorer - no cold air A/C & Heater systems - HVAC 0
M No hot air from heater, only warm A/C & Heater systems - HVAC 3
X what is this. no air except on high A/C & Heater systems - HVAC 3
D Gen 2 "no air movement" A/C & Heater systems - HVAC 0
T Intermittent Air To Dash Vents A/C & Heater systems - HVAC 2
K Blowing Warm Air after A/C Recharge, please help! Edit: Updated with Video A/C & Heater systems - HVAC 1
J 2006 Ford Explorer. Air is not coming out of the A/C panel vents. A/C & Heater systems - HVAC 4
F A/C-heat air flow control problem. A/C & Heater systems - HVAC 4
C Hot air from A/C. A/C & Heater systems - HVAC 2
C A/C blows hot air going up a hill. A/C & Heater systems - HVAC 5
L Air only comes out of the defrost vents. A/C & Heater systems - HVAC 4
Similar threads
