Excellent work on the AC
@donalds super thorough.
I haven't worked on my vehicle's AC in years, my latest 98 just quit(compressor), so it needs freon at the least. I have replaced the o-rings on most of my older cars shortly after buying them, and that has helped a ton to not have future leaks etc.
BTW, another step you can take for any system that has the quick connections(where the o-rings are and need replacing); those get leaks due to the vibration. The simple steel clamps around them do very little. I throw those away, after finding and replacing them with rigid aftermarket clamps. The early kind were aluminum, I used those on my first Crown Vic, and it lasted until over 300k miles.
The later clamps are a tough black plastic, and they cost about $15 apiece about 15-20 years ago. I highly recommend those if you can find them. Those clamps hold the connections rigid, so the o-rings will last a lot longer. They take a few minutes to install, and there is a different size for each sized connection, so several possible sizes.
