pyxis
- August 21, 2007
- Detroit
- '97 XLT
I'm in need of some assistance diagnosing a problem I'm having with my A/C. First off my explorer has the manual controls and not the electronic. The problem is that cold air does not blow when I have the setting on "A/C." However, cold air does blow when I put the setting on "Max Air."
I checked if there was refrigerant and it was a little low. I put a can of refrigerant in there and it still won't blow cold air on the a/c setting. And when I change from "max air" to "a/c" it blows cold for about five seconds before it starts blowing hot air.
Don't know if this is related but about five months ago I had an electrical problem. The cable connecting the alternator to the battery somehow got loose and caused arcing. Don't know how long that lasted but eventually it melted the terminal on top the alternator and also took out my starter. Replaced both but I did notice about two weeks later that the a/c had this problem. Like I said not sure if it's related but thought I'd throw that out there.
I'd appreciate any insight.
Thanks
Thanks
