lynnboy021
- January 17, 2010
- billerica ma
- 2004 explorer
so i did the trans fluid and filter change today and the fluid was nice and red and no burnt smell to it.... refilled the trans with 6 qts of mercon v fluid.. started up the truck let it warm up went through all the gears and kept the truck running... levied the truck and started to drain some fluid as the YouTube video showed me how. well while the fluid was draining sometimes it was red and sometimes at the end it came out like pink fluid kinda like there was air in the system.. when i bought the truck it was whining but i thought it was the ps pump so i left it alone and goes to find out that its the tranny that's making the whine.. so my questions are,
1, with the pink fluid does it mean i have a bad cooler and air in the lines? maybe a leaking cooler?
2, trans shifts good, can the whine be a bad tc, oil pump, air in tranny, valve body gasket or solenoid pack gasket??? i don't think its trans filter, i made sure it was installed right and o-rings was there..
3, can i be low in fluid?
