getthingsready
- February 19, 2009
- BC
- 99 XL
So my battery died so I had to move my car without the engine. After I changed the battery, the car started fine, but I started to have symptoms of air bubbles in my power steering system. My steering wheel vibrated violently at any movement to the left and right... so upon investigation online, I learned of the lock to lock procedure with a vacuum pump installed and the engine on... with the front wheel jacked up of course. Anyways, I can't seem to keep my vacuum and I keep aspiration air from the power steering system. I've the the lock to lock procedure about 3 times now, and each time my steering fluid ends up being frotty with air bubbles. So I am guessing I some how have a vacuum leak in my power steering system, but what is puzzling me is that I don't have any visual power steering fluid leak nor am I loosing any power steering fluid. Does that make any sense to anyone out there? Thanks in advance for your insights.
