shytot4x4
- September 23, 2003
- West Yorkshire, UK
- Not got an Explorer now..
The 'Air ride' system has not worked on my UK '98 Explorer since I bought it 2 years ago. After 30 minutes of constant running the 'Air Ride off' warning light illuminates and stays on until I next switch off the ignition. I've had my local Ford dealer look it over at service times but they have never been able to find a real fault. The latest they came up with was bad seals on the rear shocks.
Just recently I managed to acquire a bunch of parts from a wrecked Ex (I know that the air ride was working before the wreck). I have swapped out the shocks and all the components that live in the space above the rear axle - I dunno their correct names but I've swapped the compressor, the 2 rectangular recievers (or whatever), the actuator, the valve gizmo just down stream of the compressor and both rear shocks.
The system still does not work! Is there a fuse somewhere? The only mention of suspension in the fuse section of the handbook refers to a 7.5A fuse which also protects the heater and a bunch of other stuff that seems to be working OK.
Any ideas would be welcome!
TIA
Simon H
(Shytot4x4)
TIA
Simon H
(Shytot4x4)
