stackz
- September 28, 2004
- james island, sc
- 98 5.0 mountie
the bags popped on my 98 mountaineer when it got hit in the front left.
I've got replacement bags on order and I've also got a pair of front impact sensors from a 99 explorer.
will the explorer sensors work?? also, do I need to replace the clockspring in the steering wheel since the bags deployed or is it re-useable??
also, on the sensors, how do they work exactly?? the radiator support was slightly bent in from the impact but The new header panel and fender and all bolts up just fine and looks good from the outside but the left airbag sensor is somewhat tilted. Will this cause it to trip and pop the new bags or will it be ok??
I guess I can try to straighten the panel out but if I cant would it be good as -is or will I need to shim it straight??
