Airbox Mod??? | Page 3 | Ford Explorer Forums
Airbox Mod???
yea dude ive heard so much good stuff about the kuhmo's... next time you get some tires go to www.tirerack.com. you can read alot of reviews, and it really helps with decisions about tires.
Part of the reason for the airbox is the polution control system, when you swiis cheese the airbox, and/or remove the silencer you have effectively bypassed the thermactor part of the pollution controls. the purpose of the thermactor is to grab air from the heated manifold area which in turn makes your choke turn off faster (or in this case the computer program that simulates a conventional choke in the fuel injection system) and helps cut emissions by leaning out the mixture sooner. They also say it makes the vehicle more drivable during warmup but I never noticed much difference with or without ... in fact most cars with over a 8-10 years old don't have a working thermactor anymore and no one seems to even notice the difference
wow u know alot... thts awesome. well i decided im going to get a conical filter.. but thanks for the info.. its good to know
Hey got a qustion for you guys I have a 1991 and want to know where the holes go in the air box I really want to do this
I just took a 2 1/2" holesaw and made two holes in each side ... even that is probably overkill as you have a restriction after the airbox anyway ... one hole in each side would probably be enough to get the max airflow which is set by yhr restriction upstream ... more if you are looking for the sound
this is what the title says
91-04 00 01 02 Ford Explorer V6 Air Filter + Adapter
Im not sure what your a/f sensor looks like, but if it looks like that adapter it will work with your truck then your good.
there are more of the exact same forsale. the filter looks awsome in person and comes with an orange coupler too.
im sold then because $12 dollars is a rediculously low price, ive also been missing that conical filter i had in the pushrod v6!
