Alignment Specs | Ford Explorer Forums
Alignment Specs
SCMark
Anderson, SC
1997XLT
I am new to the Explorer forum, and don't know if this is buried somewhere, but I will ask anyway. What are the alignment specifications for a 1997 explorer regarding toe in, caster and camber? I have not been able to find the information anywhere. Thanks
toe, 1/8 degree in,
caster , 1/2 degree lead right wheel,
camber , form 1.2 negative, to 1.4 positive degrees,
this should get you going down the road straight,
Thanks. I have recently replace an inner tie rod, and am in need of straightening the wheels direction. This helps.
