fordpickupman
- March 18, 2011
- Cascade, ID
- 94 XLT
71 F250 Fummins
I recently picked up a fairly clean 2001 5.0 XLT for cheap due to it having an electrical problem.....
I had to put a different battery in it because it had smoked the other one.
I started trying to chase the problem down and determined that the voltage regulator must be fried as it was charging over 20 volts on a good battery. So I replaced the regulator, but no change. I had an alternator shop test the alternator and they said it was fried and not rebuildable. So I ordered a new one, they tested it and it was good. I put it on, no change.
It is getting over 19 volts at the alternator on all 3 leads while it is running. I have searched and searched on here and other forums trying to figure this out.
I also have a ‘97 5.0 XLT that has a “custom” wire ran from the Yellow/white wire of the alternator to the fuse box. I’m wondering if it had the same problem and this wire bypassed something under the dash that was causing grief.
Im at a loss at this point.
