as for the web site, just a load of generic specs on the products and nothing specific for the explorer. That's why I was asking people with practical explorer experience.
cheers
Jim
1997 FORD TRUCKS EXPLORER 4.0L 6-cyl Engine Code [E] SOHC
LUBRICANTS & FLUIDS: Lookup Another Vehicle
Engine Oil
Grade 1......API*
Signature Series 0W-30 100% Synthetic Motor Oil (SSOQT)
SAE 5W-30 Synthetic Motor Oil (ASLQT)
XL 5W-30 Synthetic Motor Oil (XLFQT)
All TEMPS......5W-30
Manual Transmission,M5OD-R1......MA
Synthetic Universal Automatic Transmission Fluid (ATFQT)
Torque-Drive Synthetic Transmission Fluid (ATD1G)
Automatic Transmission,5R55E......MA5
Differential, Front......GL-5
All TEMPS......75W-90
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
Limited Slip Differential, Rear......GL-5*
All TEMPS......75W-140 [1] [2]
SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT)
80W-140 Synthetic Long Life Gear Lube (FGO05)
Standard Differential, Rear......GL-5
All TEMPS......75W-140 [2]
Transfer Case,Warrner 4405......MA
Transfer Case,Full-Time 4WD......MA
Fluids
Power Steering Fluid......MA
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
Clutch Fluid......HB
[1] Synthetic oil is required.
[2] Limited Slip Identification: Letter & number
on plate on door lock pillar. (Models W/ Traction-Lok Rear
Axle Add 4 oz of friction modifier part no. C8AZ-19B546A
(EST-M2C118-A) or equivalent)
FILTERS:
Oil Filter Absolute Efficiency Oil Filter (EAO15)
Oil Filter WIX 51515 Oil Filter
Air Filter Absolute Efficiency Air Filter (EAA419) [1]
Air Filter Absolute Efficiency Air Filter (EAA122) [2]
Air Filter WIX 46419 Air Filter [1]
Air Filter WIX 46416 Air Filter [3]
Air Filter WIX 46253 Air Filter [2]
Fuel Filter WIX 33296 Fuel Filter
Transmission Filter WIX 58841 Auto Tran Filter [4]
Transmission Filter WIX 58840 Auto Tran Filter [5]
Oil Vapor Filter WIX 46978 Air Filter
[1] w/o Cone
[2] Panel Style
[3] w/ Cone
[4] 4WD
[5] 2WD
NGK PLUGS AND WIRESETS:
GPSERIES PLUG TR55GP NGK3403 [1]
IXIRIDIUM PLUG TR55IX NGK7164 [1]
PREMIUMIRIDIUM PLUG ITR5F13 ^ [1]
PREMIUMPLATINUM PLUG PTR5F-11 * [1]
VPOWER PLUG TR55 NGK3951 [1]
WIRESET WIRESET RC-FDZ081 [2]
[1] Plugs - SOHC
[2] SOHC (RHD)
WIPER BLADES:
Blade Class Driver Passenger Rear
ExactFit T181 T181 T122 [1]
ExactFit T141 [2]
NeoForm T16180 T16180 T16140 [2]
Winter T37180 T37180 T37131
[1] Early
[2] Late
CHASSIS LUBRICATION:
4WD
0-10 Fittings, 0 Plugs..........LM
Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCTB)
Synthetic Water Resistant Lithium Complex Grease; NLGI #2 GC/LB (GWRCR)
2WD
0-6 Fittings, 0 Plugs..........LM
CAPACITIES:
Engine, with filter..........5 quarts [1]
Cooling System, Initial Fill..........13.8 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 5R55E Initial Fill..........Not Specified
Automatic Transmission, Total Fill
5 speed 4WD 5R55E..........9.9 quarts
5 speed 2WD 5R55E..........9.6 quarts
Manual Transmission, M5OD-R1..........5.5 pints
Manual Transmission, ..........5.5 pints
Differential, Dana 35 Front..........3.6 pints [2]
Differential, Rear..........5.5 pints [3]
Transfer Case, Warrner 4405..........3 pints
Transfer Case, Full-Time 4WD..........2.8 pints
[1] When refilling, remove dipstick to provide adequate venting
and allow oil to flow into crankcase.
[2] Fill no higher than 9.5 mm or 3/8 inch below fill plug.
[3] Fill to no more than 1/4 to 9/16 inch below fill plug hole.
TORQUES:
Oil Drain Plug.....17-22 ft/lbs
Manual Transmission Maz M50D 5-SPD
Fill Plug 29-43 ft/lbs
Drain Plug 29-43 ft/lbs
Transfer Case
Fill Plug 14-22 ft/lbs
Drain Plug 14-22 ft/lbs
Transfer Case Full-Time
Fill Plug 13 ft/lbs
Drain Plug 13 ft/lbs
OTHER TOP QUALITY PRODUCTS:
Mothers® Car Care Appearance Products
By-Pass Oil Filters
PI Performance Improver Gasoline Additive
Product Recommendations and Drain Interval Chart
