Another door locking issue... | Ford Explorer - Ford Ranger Forums - Serious Explorations
  • Register Today It's free! This box and some ads will disappear once registered! Once registered you can join the Elite Explorers to eliminate the ads from the website and more!
jdes
Houston
92' explorer
When I use the remote lock fob, it would take several attempts unlock the door. There were no audible indicators of the first few attempts. Naturally I thought it was the battery but was shown as at "capacity".
The first time it unlocks, the driver's door remains locked. An additional attempt would usually unlock the driver's door.
Now none of the doors will unlock. I've always been able to lock the doors but now am afraid to do so as the doors may not unlock.
I've searched the threads and have seen a few lock issue which may be my issue but they are all slightly different. Would installing an aftermarket alarm fix the issue? I need more insight on this thanks guys.
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
jdes
Houston
92' explorer
Am I posted in the right section?
Midwest Dually
Northern Wyoming
1995 Limited
If you are absolutely certain your battery on your key fob is 100% up to speed with power, then your actuators may be worn out. Do you have to hit the unlock switch on your door panel several times?
Jstcruz
Deltona, FL
97 Ex XLT & 84 Ranger
It is a possability that your battery in your truck is tired out. If it isnt kicking the amperage it may cause the actuaters to lag. It would be strange for all of them to start acting up all at once..
bobflood
Powder Springs, GA
1997 Eddie Bauer V8 2WD
The first push of the fob should unlock only the driver's door; a second push immediately after should unlock the remaining doors and hatch. First thing to do is change the battery in the fob. Second thing is to clean out where the buttons push down to make sure that isn't cruded up. Then, replace the fob with a new one. I would do all of these things before I started looking at car battery, actuators, etc.
