- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
I am using a Scangauge to monitor my OBDII information. It does take a good while for the heat to build up, my fan runs very little. It cycles on every 30-60 seconds or so, for a few seconds at a time, in our Spring heat.
The temp probe of the CD controller does stay in fairly well, in the fins. I placed it where I did knowing that my Scangauge would give me readings from the thermostat sensor. If the temps don't remain where they should be, I can adjust the controller, or move the sensor if need be.
Place your sensor where it will be secure, tapping into the stock sensor is also a good option. It just needs to be consistant, so you can adjust the running temperature. I don't want to see readings over about 210, or under about 180, 195 is about ideal.
