natenkiki2004
Blue Bomb!
- November 3, 2013
- Location
- North Idaho
- 1991 & 1994 Explorers
3 weeks without fuel in the injectors? Yea, they could be stuck closed or open, leaking too much fuel. I forget, have you pulled plugs after running the engine and then letting it sit? Were any wet? If they're all bone dry then the injectors are probably just closed. You've said your budget is tight but how about time? Would it be out of the question to yank injectors from the 93, just to test? Having them out for an hour or two won't hurt. I'd still suggest sticking a drop or two of oil into the basket, just to keep them moist inside. When I did mine, I used 2-cycle oil, something thin that mixes (gets washed away) with gas easily.
