DavidMeerbach
- February 28, 2010
- Washington, DC
- '98 XLT
I'm a new member to this forum, and have browsed the threads to see if anyone had run into a similar problem, but nothing so far. Here's the problem:
During the heavy snow two weeks ago in DC, I put the truck (Explorer 98XLT, 96 k) in 4low, and afterwards it remained stuck in 4 low. Tried the usual (neutral, foot on brake, etc), but did not work. Based on some threads in this forum, I removed the transit case, and manually with a pair of pliers I moved the transit back to 2D. That solved the problem of the truck steering like in 4 low, but the engine still behaves like it's in 4 low: heavy sound, slight shaking, and it's clearly still responds to a heavy torque from the transmission. Took it for a spin around 6 miles, not exceeding 20 mph. Tried all - battery off to reset the sensors, rocking the car back and forth, etc. Took it to the workshop (not a Ford specialist), where just based on the engine sound the repair guy diagnosed that the entire engine needs replacement : 2000 US. Seems a bit excessive, especially since there were no engine problems before I put it in 4 low.
Anyone had a similar issue, or any idea what could be the problem here? Many thanks!
