Any info on swapping pre 98 5.0L into 99 Explorer | Ford Explorer Forums
SploderXLT
Richmond, VA
99 XLS
I cant find any info on this. I'm sure someone has done it. I already have the 97 5.0L explorer and the 99 OHV explorer that I want to put the motor in. The fuel system is different, but thats an easy fix. Not having PATS on the ECU should be helpful, but the harness is different. Should be able to splice the harnesses together if I had the "pinouts" for each harness. Any info would be helpful
